Is it possible to get more horsepower from the OM 401.914 motor without adding a turbo?
Has anybody added a turbo to the OM 401?
Increasing power from MBZ OM 401.914
Joaquin Suave
- Uwe
Hi Joaquin,
30 - 40 additional hp should be possible by increasing the diesel injection volume.
The low-end option is to turn the injection volume screw until the engine throws out too much soot.
High-end option is to put the injection pump on a test bench to find the optimal adjustment for all charge states.
Joaquin Suave
- Uwe
Fitting the motor with a turbo is possible for sure. Main problem will be the danger of overheating the engine. Is the OM401 fitted with a piston crown cooling?Joaquin Suave hat geschrieben:How about fitting the motor with a turbo like the OM441?
