Increasing power from MBZ OM 401.914
Joaquin Suave
#1 Beitrag von Joaquin Suave » 2007-05-02 17:16:50
Is it possible to get more horsepower from the OM 401.914 motor without adding a turbo?
Has anybody added a turbo to the OM 401?
#2 Beitrag von Uwe » 2007-05-04 9:52:32
Hi Joaquin,
30 - 40 additional hp should be possible by increasing the diesel injection volume.
The low-end option is to turn the injection volume screw until the engine throws out too much soot.
High-end option is to put the injection pump on a test bench to find the optimal adjustment for all charge states.
Joaquin Suave
#3 Beitrag von Joaquin Suave » 2007-05-04 19:43:58
Thanks Uwe,
How about fitting the motor with a turbo like the OM441?
makabrios
#4 Beitrag von makabrios » 2007-05-04 20:13:48
Buenos Dias,
Mercedes offered the V6 turbocharged with 330HP .
Unfortunately I don´t have the specs at hand.
Manufacturing years were the early 990ies from the last millenium.
Best regards
mak
#5 Beitrag von Uwe » 2007-05-08 10:10:04
Joaquin Suave hat geschrieben:How about fitting the motor with a turbo like the OM441?
Fitting the motor with a turbo is possible for sure. Main problem will be the danger of overheating the engine. Is the OM401 fitted with a piston crown cooling?
