MD bolt pattern and Trilex wheels
wilco
#1 Beitrag von wilco » 2013-06-13 0:19:22
1978 Magirus Deutz D17 FA ALLRAD
What is the bolt pattern? 10 X ??? and the center opening size? 280mm?
What is the largest tire that anyone has put on a 8.5 X 20 Trilex?
CoDa
Re: MD bolt pattern and Trilex wheels
#2 Beitrag von CoDa » 2013-06-13 8:41:15
Trilex-Dimenisions
Grüße Cord
#3 Beitrag von Pirx » 2013-06-13 11:12:06
wilco hat geschrieben:1978 Magirus Deutz D17 FA ALLRAD
Hello wilco,
the bolt pattern is 10 x 335 mm. The center opening size is 281 mm.
But you need not stay with the TRILEX rim system. As I could see on one of your photos of the truck, it does not have the "real" TRILEX rims. It has the TRILEX adapter rims. This means, you can throw them away and use just every common truck rim with the above 10 bolt pattern.
wilco
#4 Beitrag von wilco » 2013-06-14 0:41:23
They have a 281 mm center opening??
wilco
#5 Beitrag von wilco » 2013-06-14 0:42:17
THANK's FOR ALL THE HELP!!!!!!!!
#6 Beitrag von Pirx » 2013-06-14 9:57:32
wilco hat geschrieben:every common truck rim with the above 10 bolt pattern.
Should be an international Standard. If not, just enlarge the diameter of the center opening, as some of the guys here did with russian rims that obviously do not comply with that standard.
