1978 Magirus Deutz D17 FA ALLRAD
What is the bolt pattern? 10 X ??? and the center opening size? 280mm?
What is the largest tire that anyone has put on a 8.5 X 20 Trilex?
MD bolt pattern and Trilex wheels
Re: MD bolt pattern and Trilex wheels
Hello wilco,wilco hat geschrieben:1978 Magirus Deutz D17 FA ALLRAD
the bolt pattern is 10 x 335 mm. The center opening size is 281 mm.
But you need not stay with the TRILEX rim system. As I could see on one of your photos of the truck, it does not have the "real" TRILEX rims. It has the TRILEX adapter rims. This means, you can throw them away and use just every common truck rim with the above 10 bolt pattern.
They have a 281 mm center opening??
THANK's FOR ALL THE HELP!!!!!!!!
Should be an international Standard. If not, just enlarge the diameter of the center opening, as some of the guys here did with russian rims that obviously do not comply with that standard.wilco hat geschrieben:every common truck rim with the above 10 bolt pattern.
