Hello everybody,
First....sorry I can read german but writing is to difficult!!! And google translate makes weird creations! ;-)
I have an 170D11 with 176ps engine and XZL 14.00R20 tyres . I spoke to a person at abenteuer allrad about changing the settings of the ESP to gain more power.
Does anybody have experience with changing the ESP on the Magirus 170D11? I am wondering what happens with:
- fuel consumption (difference before and after changing with same driving speed)
- reliability ( axles, engine, gearbox )
- What is the best place to go in Germany for changing the settings?
And I heard a person told me at Abenteuer Allrad that the frontaxle could hit the oilpan while driving offroad. Does anyone have experience with this?
Best regards Sjoerd
Leistung / power 176ps + oilpan QUESTION
Re: Leistung / power 176ps + oilpan QUESTION
... search for: Rüdiger (die Pumpe) Schramm and Blechölwanne ...
Hello,
Thank you for the answer! I got in contact with herr Schramm and somewhere this summer I will send him the pump!
About the oilpan. Do I read it correctly? :
If the original springs and shocks (170D11 FA - THW) are working properly and as long as I don't drive de Dresden-Breslau Rally at full speed the change of
a broken oilpan is very small? I drive 95% normal roads and planned an offroad trip in Morocco on pistes.
I wouldn't like to raise the suspension. I had a syncro before and as soon as you start changing 1 item of settings there will be 10 items more that need to be changed!
Best regards,
Sjoerd
Best regards,
Sjoerd
- Bahnhofs-Emma
Greetings!
sounds very realistic...as soon as you start changing 1 item of settings there will be 10 items more that need to be changed!
Greetings!
