I have a 78 MD D17 FA end the Governor is set to 2300 RPM.
I would like to turn it up the 2600, but haven't found any info on how to do it.
My engine manual has very little information on the INJECTION pump.
Pump # 72241197
pe8a95d410ls245
0400648773
F8L413F Injection pump RPM speed up.
Re: F8L413F Injection pump RPM speed up.
Hi wilco,wilco hat geschrieben:I have a 78 MD D17 FA end the Governor is set to 2300 RPM.
Pump # 72241197
pe8a95d410ls245
0400648773
you will find some basic info about the injection pump and how to modify it here:
http://www.unimog-forever.com/Grease/Di ... Diesel.htm
