deutz motor
LaNdRe
deutz motor
#1 Beitrag von LaNdRe » 2013-03-21 23:47:42
hi !! I have a question
its possible to mount bf6l913 (168hp) on magirus 130M7 ???? change the original f6l913 (130hp) with bf6l913 (168hp) like iveco magirus 80/16
its possible to change also the getriebe ???
andrea
Re: deutz motor
#2 Beitrag von OliverM » 2013-03-21 23:58:19
Yes , it is.
greetings
Re: deutz motor
#3 Beitrag von lura » 2013-03-21 23:58:22
it's possible, the differenz between the engines is the turbo and the beam. the 130hp-engine turns 2500/min, der 168hp-engine turns 2650/min. the little pulls 422 Nm, the big one 487Nm.
LaNdRe
Re: deutz motor
#4 Beitrag von LaNdRe » 2013-03-22 0:05:22
and its good choice to put 6 march getriebe original from 168-11, or its possible to use original 5 march getriebe ??
LaNdRe
Re: deutz motor
#5 Beitrag von LaNdRe » 2013-03-22 0:05:54
gears not march, sorry
Re: deutz motor
#6 Beitrag von lura » 2013-03-22 0:22:26
more cylinders, more displacement, more gears, bigger wheels is always better. :D :D :D
LaNdRe
Re: deutz motor
#7 Beitrag von LaNdRe » 2013-03-22 0:23:57
are both 6 cylinders, I have big tyres
