heating system of the cabin damaged
LaNdRe
#1 Beitrag von LaNdRe » 2012-10-21 18:56:45
hi I have magirus 130M7 and I'm looking for the heating system of the cabin, mine is damaged......in italy is very difficult to find parts of this truck, in this forum i see a lot of very competent people !!!
you can help me ???
Veit M
Re: heating system of the cabin damaged
#2 Beitrag von Veit M » 2012-10-22 18:10:46
Hi Landre,
this part contains a ventilator and a heat exchanger (cooler).
You should open and check which part is broken.
Is it loosing oil? In this case look for a company which is able to restor coolers. May be it is possible to solder.
If the ventilator is broken you may be able to repair yourself. In most cases the collector coal is gone, sometimes the bearings need repair.
I think you will see more when opened.
If there is noc chance to repair may be a replacement is possible (may need some workaround).
Good luck
Veit
LaNdRe
#3 Beitrag von LaNdRe » 2012-10-23 19:09:54
hi, yes the problem is connector.....i open the radiator for ask the cost of repair but is more convenient change all radiator.....i find it on ebay from germany !!!!
