fluids 170D11
feex
fluids 170D11
#1 Beitrag von feex » 2010-04-22 10:54:56
hallo, !I have another question, which types of oils and fluids I should put to diferentials and getreibe and another places while changing? thanks
#2 Beitrag von felix » 2010-04-22 18:57:41
Hello,
axels and distribution Gearbox SAE 90, SAE 80W90 or SAE 85W140 in Quality GL5.
Gearbox SAE 80W90 in Quality GL4
Don't put GL5 in your Gearbox, it will destroy the synchonisation.
#3 Beitrag von Wilmaaa » 2010-04-22 19:05:03
felix hat geschrieben:distribution Gearbox
For those who haven't heard this expression before, the common technical term is transfer box (Verteilergetriebe). :)
feex
#4 Beitrag von feex » 2010-04-22 19:05:23
Felix: thank you! I will change all, end do you remeber which oil to power steering (servo)
by the way, Is it there some way how to make the 170D litle bit less "lazy" ? some faster axle, or something?
Kami
#5 Beitrag von Kami » 2010-04-22 19:11:55
feex hat geschrieben: by the way, Is it there some way how to make the 170D litle bit less "lazy" ? some faster axle, or something?
why are want to change here sth? Nobody would give you the money back...or did you change your mind about selling it?
Regards
Kami
feex
#6 Beitrag von feex » 2010-04-22 19:22:52
kami: Idont understand what do you mean by why are want to change here sth?
Iam not allready sure If I want to sell it or not, but propably yes, so than is better when I weld it and repair things which is need it. [/b]
#7 Beitrag von felix » 2010-04-22 21:32:21
Hello,
for the power steering you should use ATF (Automatic Transmission Fluid) Its about 3 Liters.
feex
#8 Beitrag von feex » 2010-04-22 23:15:53
felix, thankyou, I was thinkink if there is some special.
