Kalle12
- Selbstlenker
#1
Beitrag
von Kalle12 » 2026-05-07 17:09:24
Hello fellow truck drivers! The hydro steering pump on the old beater (Iveco 90-16) needs replacement. The spare part number is Bosch 0510 515 314. Has anyone on this friendly forum found a place to buy the part, or a suitable replacement part number? This part number yields zero search results. I know one way is to contact Bosch and find which part number replaces this, but I thought it was a good idea to ask here as well...
EDIT: Well, it appears I have found the part. This came up:
https://boschrexroth-ind.com/product/bo ... 510515314/
And this page sells it for EUR:
https://www.sp-spareparts.de/en/p/05105 ... 0510515314
Does anyone know, are there alternatives to this, like aftermarket parts similar to DT Spare Parts?
AndyAntony
#2
Beitrag
von AndyAntony » 2026-05-08 11:39:20
Hello,
i also had an issue with my hydro-stearing - so I disassemblied the pump - it is the same pump you have (BF6L913 Engine on my MD120-16ANW) - it is a simple gear pump - did you disassemble it? are you sure you need a whole replacement? I only needed to change the sealings, the gears and all other mechanical parts where fine.
If you might buy the new pump, please consider the picture in the online-shops most time is just a sample picture!
BR
Grauerwolf1802
#3
Beitrag
von Grauerwolf1802 » 2026-05-11 16:11:53
Die Pumpe gibt's ab 250 Euro bei eBay 0510515314
Oder Iveco TN 42200611
Gruss grauerwolf
