OM441 -> OM441 LA conversion
sprocket3
#1 Beitrag von sprocket3 » 2024-08-18 11:45:51
Hello,
Has anything changed an OM441 to a higher power OM441LA or similar?
I found a truck that I'm interested in buying, but it has the low power non-turbo motor. Are there major internal engine differences or is it possible to us bolt on parts from an LA engine somehow.
Any ideas on how to get more power from a stock non-turbo engine would be good to know.
Cheers,
Mat
1998 Actros 1831 Expedition Truck
unihell
Re: OM441 -> OM441 LA conversion
#2 Beitrag von unihell » 2024-08-18 17:35:54
sprocket3 hat geschrieben: ↑
2024-08-18 11:45:51
der wichtigste interne Unterschied ist die Nockenwelle. Sauger und Turbo/LLK habe grundverschiedene Steuerzeiten, weil der Sauger eine viel längere Spülzeit braucht.
Gruß Helmut
Wat wellste maache
Wat soll dä Quatsch
sprocket3
#3 Beitrag von sprocket3 » 2024-08-19 19:09:32
Ok. Is there a way to increase power in the OM441 to higher levels?
