Achsübersetzung MAN L2000
teeti
#1 Beitrag von teeti » 2022-10-13 19:19:01
Hi, could anyone please help figure this out, I have managed to gather the following data:
Getriebe 4106
Vorderachse VA9-054001
Hinterachse H9-067001
I figured the axles are both AP-Achsen, and the gearbox is Eaton. I'd like to know the axle ratio, is it possible to figure it out with only the data above? I found this manual which mentions different ratios for different varieties of the gearbox, but all I have is "4106": https://www.eprogear.com/eaton-4106-520 ... anual.html
Maybe one of the varieties is typically installed on this particular truck model (8.223)?
Sere
Re: Achsübersetzung MAN L2000
#2 Beitrag von lura » 2022-11-28 2:18:12
Hello Sere, I dont believe, that the ratio is to find out without addtional techical information. In older trucks the ratio numbers were stamped in on the axle.
Regards
