More power
Verfasst: 2008-07-22 11:16:35
von jafo
Hello,
Is it possible to get more power out a Iveco Magirus engine
6086 cc 118 KW ??? How now something more about this ?
thanks and sorry but i can't write germain.
Verfasst: 2008-07-22 18:16:07
von Uwe
Hello Jafo,
the Deutz BF6L913T is available with up to 200 HP in its turbo intercooler version. But this motor differs in many details from your type (piston cooling, ...). Easiest way to get more power is to increase the quantity of injected fuel, disadvantage of this method is the increase of particulate emission (I don't know if you have any exhaust emission test). You may ask 'Rüdiger - die Pumpe- Schramm' for a professional way to modify the injection pump.
Verfasst: 2008-08-01 17:16:34
von jafo
Uwe hat geschrieben:Hello Jafo,
Thanks , and do you now of the Deutz BF6L913T engine fit's in my truck ?
thanks,
jafo
Verfasst: 2008-08-01 19:58:41
von Wilmaaa
Hi Jafo,
if you tell us which type of truck you've got, we'll tell you whether changing the engine is just an effort or loads of work. ;)
Wilmaaa :cool:
