Multiple 170D11 questions
BlackHammer
Re: Multiple 170D11 questions
Awww... So is this just so my brakes don't lock up during normal operation or does it help for off-road driving?
This valve only regulates the brake pressure depending on the axle load .BlackHammer hat geschrieben: ↑2019-03-27 20:13:23Awww... So is this just so my brakes don't lock up during normal operation or does it help for off-road driving?
I tried to explain beginnig with "blue marked":...
BlackHammer
Apologies. English isn't my native language either and I wasn't sure if "avoid slippage of the rear axle" meant avoid wheel lock or avoid spinning of the wheels.
Thanks for all of the help!
BlackHammer
So the saga continues.
Another roadblock.
I purchased some wheels. Seller claims that they fit 395/85r20 tyres. His listing shows photos of the wheels mounted on 395/85r20 tyres. My truck guy is saying they don't. They have a normal small flange, not the larger military flange. Anyone have a guide on wheel sizes and flange types? I can't find a definition of 10.00v-20 vs 10.00-20 vs 10.00w-20 wheels.
The listing for the wheels show them mounted on 395/85r20 and I confirmed via phone AND email that these wheels fit 395/85r20 tyres. The seller is a reputable surplus military dealer in the USA. They still insist that they do when clearly they have the incorrect flange for this tyre. Help? I'm at a bit of a loss. This is delaying the rest of my project as I wanted to confirm final height before sending the truck for fabrication next week (guess that's delayed AGAIN!).
Below are the new wheels (split apart) on top of a standard MRAP wheel mounted to the 395/85r20 tyre. As you can see, the new wheels don't have the right flange yet the seller insists that they fit.
Another roadblock.
ETRTO Standards Manual says:BlackHammer hat geschrieben: ↑2019-04-17 2:35:22I purchased some wheels. Seller claims that they fit 395/85r20 tyres. His listing shows photos of the wheels mounted on 395/85r20 tyres. My truck guy is saying they don't. They have a normal small flange, not the larger military flange. Anyone have a guide on wheel sizes and flange types? I can't find a definition of 10.00v-20 vs 10.00-20 vs 10.00w-20 wheels.
10.0-20: 5° tapered rim, flange height = 51 mm
10.00-20 V: flat base rim, flange height = 44 mm
10.00-20 W: flat base rim, flange height = 51 mm
Michelin says:
tires XZL 395/85R20: approved rims = 10.00 W, 10.00, 10.00 V
https://www.michelintruck.com/tires-and ... r/info/xzl
BlackHammer
Thank you very much for this information. Cheers!
