I'm looking for the dimensions of the Achsklotzen 80mm high and Federbriden for lifting up the 90-16 with 80mm. Adjusting Stossdaempfer as well? Which size? Can someone help?
Mit freundlichen Grussen,
Ivan
Niederlande
Achsklotzen und federbriden Iveco Magirus 90-16
Ivan de wit
Ivan de wit
Re: Achsklotzen und federbriden Iveco Magirus 90-16
The original numbers for a 110-17 (same as 90-16) are:Ivan de wit hat geschrieben:I'm looking for the dimensions of the Achsklotzen 80mm high and Federbriden for lifting up the 90-16 with 80mm. Adjusting Stossdaempfer as well? Which size? Can someone help?
Ivan
Niederlande
Federn: 42211084
Federbugel: 42200486
Hey,
for "Achsklotzen" you just take steel "Klotzen" in which you drill a hole for the central pin of the leaf spring (Herzbolzen). You can also stack pieces of steel bars and weld it to get "Klotzen", if "Klotzen" is not available.
Longer "Federbrieden" and "Herzbolzen" you can get from companies that sell leaf suspension items. I case they can make them to size. One example is "Federn Bischoff", they can be found online, but there are many more companies specialised to suspension.
Best regards,
P.S: @Ivan: Did you verify that 110-17 have identical parts?
Best regards,
Ivan de wit
Brauche neue Stossdaempfer fur Iveco 90-16. Hoherlegung 50mm so längere Stossdaempfer nötig. Welche brauche ich? Iveco ist schön hoger gelegt
Vielen Dank.
