Magirus 170d11 Noise in 2. Gear. Should I worry?
Verfasst: 2015-05-26 10:20:07
von Peterdenmark
Suddenly my truck has started to make a noise in 2. gear. It is a "rrrrrrrrrrrr" metallic. If I hold the gearstick the noise disappears. It is only in 2. gear. Seems to be a vibration that comes up through the gearstick.
Any experiences? Should I not use the gearbox at all, or can I just avoid 2. gear? Or is it "normal"?
Thank you
Re: Magirus 170d11 Noise in 2. Gear. Should I worry?
Verfasst: 2015-05-27 12:17:50
von Uwe
Hi Peter,
did you check the gear linkage if no parts are loose and if guidance is ok? I don't think the noise is coming out of the gearbox...
Cheers
Verfasst: 2015-05-27 13:21:58
von saharastar
Hello Peter,
I am 170 D driver as well and encountered similar behave with noise.
However I realized meanwhile that it doesn't come from the gearbox itself. I found out that it is the stick itself because the handheld- bowle at the upper end (what you hold in hand) contain a little screw-nut inside wich was wobbeling (loose hold) and cause the metalic noise.
Hope this is of help/assistance
Best Regards Sascha
Verfasst: 2015-05-27 22:16:55
von Peterdenmark
Thank you very much! It is probably something simple like that, I will check the linkage soon :D
:unwuerdig:
