front axle seals
nessie
front axle seals
#1 Beitrag von nessie » 2010-03-28 1:28:20
hello/
we are looking for the part number of the font axle swivel housing seal. picture enclosed, and we would like to know the part number for the left hand head light lens.
we need to order these from germany and DHL them here to chile.
the axle seal looks like it has been ill fitted and crimped or is this how they come.
manys thanks again
david
Zuletzt geändert von nessie am 2010-03-28 3:21:39, insgesamt 1-mal geändert.
kryzom
#2 Beitrag von kryzom » 2010-03-28 10:33:45
Gidday,
Font axle swivel housing seal
A 322 331 00 08
Kryz
nessie
gaskets
#3 Beitrag von nessie » 2010-03-28 15:13:50
thanks for that we have decided to get the online parts EPC so should have all the numbers for now, if we can work out how to use it :wack:
cheers
david
Re: front axle seals
#4 Beitrag von Pirx » 2010-03-29 13:14:28
nessie hat geschrieben:hello/
manys thanks again
david
Hi David!
The part number for the front axle swivel housing is already in the PM I sent you last week.
For the left hand head light lens: I am not sure if you are talking about the glass or the reflector?
A 000 826 51 90 glass LH (for head light from supplier HELLA)
A 000 826 60 90 glass LH (for headlight from supplier BOSCH)
A 000 826 32 81 reflector LH (for head light from supplier HELLA)
A 000 826 39 81 reflector LH (for head light from supplier BOSCH)
Please make sure you know, which supplier your headlight is from. Otherwise the parts won't fit!
Another idea: why don't you convert your truck to the more powerful halogen (H4) headlights that are only available in south america? Many people here would like to do that, but we can't get the parts in Europe ...
More Info (in german) here:
http://www.allrad-lkw-gemeinschaft.de/p ... hp?t=18905
