It's time for us to think about the water system for our truck. It seems that there are at least two common piping systems in use, Uniquick and John Guest. JG is more prominent in the web, but which would you guys recommend and why?
When it comes to pumps, is Shurflo the way to go, or are there better value pumps available too?
My initial idea for a setup is:
FILTER -> TANK -> PUMP -> EXPANSION TANK -> HEATER -> TAPS (kitchen + toilet/shower). Is it good to have a single filter before the tank, or would it be better after it? I guess there should also be pressure gauges and drain valves here and there, but not really sure where and why
I have the selbstausbau dvd, but I'm writing in hope that someone would like to chat in english. If you know a good thread in german, please recommend it. I can translate it once I find one, but it seems to be difficult to find them using search.
