Hi Kveite,
some comments from my side.
Kveite hat geschrieben: ↑2018-10-16 23:52:50
Is it easy enough to swap for a newer OM900 series engine for power and lower fuel consumption? Is it at all an idea to look for higher revving engines like a Duramax to get speed “the easy way” or am I far off as the torque figures are not usable for a higher revving engine and it probably wouldn’t work very well?
Since the OM906 both and the OM904 where on board of the late LN2s replacing the OM366LA it should be possible theoretically, no idea how much hours would be necessary but if you do not do it yourselves it probably would cost a couple of thousands of Euros + the engine itself.
Additionally it would be necessary to adjust the cabin engine tunnel, since the intercooler respectively the turbo-hoses ask for more clearance.
I don’t know the axle codes
You may post the VIN of your truck, some have access to Mercedes-Benz' works data and are able to detect the type of axles and the transmission ratio. The VIN is on your car papers starting with WDB6... and has total 17 digits if I am not mistaken
Not sure if engine swaps are common on these and how easy it would be to adopt a new engine to the configuration.
quite some work to do
Kveite hat geschrieben: ↑2018-10-17 1:02:23
I hope to get some insight as I’m sure swapping the OM 366 with something else must have came accross somebody else’s mind before. Not that it’s a bad engine.. Perhaps the clutch gearbox input shaft combo is not very adoptable for other setups.. I have the integrated 4x4 gearbox in mine, but I have heard there’s an external transfer box that works with a regular 2wd gearbox, if the gearbox needs to be swapped with the engine.
Changing the engine or giving the existing engine more power respectively more torque does not make the vehicle automatically faster, since the total high end speed is limited by the total transmission ratio which results from 4 factors:
- gear box respectively the applied gear _click_
- the transfer case
- the axle transmission ratio --> modifying would be challenging and expensive too
- the wheele size
So, you have a couple of options to follow different targets. Some have changed the main gear box, some have modified the axles transmission ratio some have have tires with higher circumference. Ohters have a combination and/or additionally a tuned engine
What would be your targets?
- Higher end speed respecitvely lower revolution level? --> one idea would be to change gear box towards the GV4 65 6/9,0 it is a kind of 12-speed gear box highest gear is translated 0,83 --> _click_
- More torque to hold speed rising dunes and mountains? --> tuning the injection pump and related measurements and/or mounting an intercooler --> _click_
By the way, we like pictures, would you like to post someones of your truck? And, where are you from?
Greetings
