What kind of service hatches have you used for Zeppelin containers? Everything I find is for wall thickness up to less than 45mm. Would be nice to find a hatch that's about 600x1000 and sturdy. But still cheap.
Thanks!
"Serviceklappe" for the Zeppelin FM2 wall thickness
Re: "Serviceklappe" for the Zeppelin FM2 wall thickness
... immer mit der Ruhe...
.. und dann mit nem Ruck.
I bought the same one and would strongly advise against it for any proper offroad use. Those things are all plastic, including the hinges. Unless you use your allrad only to go shopping, its only a matter of time before it dies. The original lock system is so weak (plastic like the rest of it) you can break it open by hand without tools.
He asked not for 4X4 and for a cheap one.
Actually I've decided to go with the tourfactory hatch. The price is ok, and I got a good service (fast reply) from them. Haven't ordered anything yet, though.
Good alternatives are still welcome.
