Need bigger tires....
wilco
#1 Beitrag von wilco » 2013-06-13 0:23:36
wilco
Re: Need bigger tires...........anchor
#2 Beitrag von wilco » 2013-06-13 0:28:02
Gebraucht ein 1971 M34 als ein Windenanker
used a 1971 M34 as a winch anchor
klettermaxe
#3 Beitrag von klettermaxe » 2013-06-13 16:12:44
No ... better a few ballons filled with helium :D ;) !
But i guess you had a lot of fun with playing in the mud there ;) .
Greetings
Klettermaxe
Was ist denn da hinter der nächsten Ecke ... ich geh mal schauen.
Sprinter 215 CDI
Iveco/Magirus 90-16AW & 80-16AW
felix
#4 Beitrag von felix » 2013-06-13 19:43:44
Hello Wilco,
less tyre air pressure should also do it. 1.2Bar on your front tyres and this don't happen again. Ground pressure equals tyre air pressure. Bigger tyres are for less pressure, if 1.2 Bar is not sufficient you can use 14.00 for 0.9Bar oder 16.00 for 0.7Bar.
MlG,
wilco
#5 Beitrag von wilco » 2013-06-14 0:26:42
It was to late to deflate.... and I havent taped into the onboard air for tire inflation.
felix
#6 Beitrag von felix » 2013-06-16 14:23:11
it's never to late to deflate. And having the onboard air ready for tyre inflation is mandatory. Also you should look for sand leaders or something like it, if you want to get out of such a situation yourself. And don't use just a war shovel, digging a whole truck out of the mud can be a real job which requires a real shovel. Something you can operate while standing upright.
Aircooled regards,
wilco
#7 Beitrag von wilco » 2013-06-17 20:06:21
I got stuck in my back pasture, so I just used my Deuce and winched it out.
I have lots of kit for off roading adventures, but when you have another big truck handy....
wilco
Re: Need bigger tires.... HAVE BIGGER TIRES
#8 Beitrag von wilco » 2013-08-02 4:16:13
14.00r - 20
49.5 in 127.7cm
Now it runs 56 MPH at 2500 RPM ( 95kph)
wilco
#9 Beitrag von wilco » 2013-08-02 4:22:00
more pic
good drum cooling...
Bluekat
#10 Beitrag von Bluekat » 2013-08-02 6:55:39
...now it look´s very nice... :rock:
http://bluekatk.blogspot.de/
stef@n
#11 Beitrag von stef@n » 2013-08-02 8:31:36
... and now the same test as in the first pictures! :cool:
Greetings
