hi !! I have a question
its possible to mount bf6l913 (168hp) on magirus 130M7 ???? change the original f6l913 (130hp) with bf6l913 (168hp) like iveco magirus 80/16
its possible to change also the getriebe ???
andrea
deutz motor
Re: deutz motor
Yes , it is.
greetings
greetings
Re: deutz motor
it's possible, the differenz between the engines is the turbo and the beam. the 130hp-engine turns 2500/min, der 168hp-engine turns 2650/min. the little pulls 422 Nm, the big one 487Nm.
Re: deutz motor
and its good choice to put 6 march getriebe original from 168-11, or its possible to use original 5 march getriebe ??
Re: deutz motor
gears not march, sorry
Re: deutz motor
more cylinders, more displacement, more gears, bigger wheels is always better.
Re: deutz motor
are both 6 cylinders, I have big tyres
