Mercedes 914 Exhaust System
WOODSMAN
#1 Beitrag von WOODSMAN » 2012-07-13 23:24:39
Well due to age (although done 38,000KMS from new now) and off road twisting the front section of the exhaust system needs to be changed as broken and the box and exit pipe show signs of bad tin worm/rust.
Mercedes said front section (£130)no longer available in stock and the middle box £300 and the back pipe £30 still available.
Several people on the forum have these trucks and has an upright method been done with a flexi hose to avoid breaking behind the two small manifold pipes.
Alternative is stainless at original place and £800
Is the original system there to keep batteries and air tanks warm in wintertime and gearbox oils?
Pictures and ideas please.
allroads
Re: Mercedes 914 Exhaust System
#2 Beitrag von allroads » 2012-07-15 19:55:19
:D
Zuletzt geändert von allroads am 2012-08-01 9:21:57, insgesamt 2-mal geändert.
WOODSMAN
#3 Beitrag von WOODSMAN » 2012-07-25 15:55:42
WOODSMAN hat geschrieben:
unihell
#4 Beitrag von unihell » 2012-07-31 0:09:56
Andreas Obermüller fertigt Auspuff-Anlagen für den 406 aus Edelstahl.
guckst du http://www.mogauspuff.de/
Bei ebay in Standard-Metall
Hosenrohr Art Nr 251003982367
Schaldämpfer Art Nr 251003981854
Endrohr Art Nr 251003982485
Gruß Helmut
Wat wellste maache
Wat soll dä Quatsch
WOODSMAN
#5 Beitrag von WOODSMAN » 2012-07-31 18:38:11
unihell hat geschrieben:Hallo
Thanks but there is some confusion!! The vehicle we have is a MB914 AK-31 and NOT A U406 like in the pictures from someone else posting. :eek:
Perhaps these should be removed to avoid more confusion and with the English/German translation. I will find the part numbers and post later. Thanks. :(
