Manai Project Truck
tintas
Re: Manai Project Truck
#31 Beitrag von tintas » 2019-06-17 19:12:31
Install new diesel tanks.
Portugal
tintas
#32 Beitrag von tintas » 2019-06-17 19:14:06
Portugal
#33 Beitrag von Pirx » 2019-06-17 21:11:27
Tolle Idee, für den Tankträger in den Obergurt des Rahmens zu bohren!
It is not a very good idea to bore into the upper side of the vehicle longitudinal rails, as you did for the front left support of the tank. All the truck manufacturers do not allow that, because this might cause a break in the rail under heavy load and stress.
tintas
#34 Beitrag von tintas » 2019-06-18 13:14:58
Ok, you're right, but I made the holes in the very strong reinforcement inside the winch structure. I hope there is no problem, I've done some tests and everything is fine.
Portugal
tintas
#35 Beitrag von tintas » 2019-06-18 14:32:01
I changed the air filter to put snorkel behind the cabin.
Portugal
tintas
#36 Beitrag von tintas » 2019-06-18 14:48:43
The cabin hydraulic were placed further forward, with the separ filter behind.
Portugal
tintas
#37 Beitrag von tintas » 2019-06-25 17:05:08
Next step, working in the cabin, was cut and welded to another cabin for smaller.
Portugal
tintas
#38 Beitrag von tintas » 2019-06-25 17:11:35
Portugal
tintas
#39 Beitrag von tintas » 2019-06-25 17:17:10
Portugal
