Hi, I'm Tim from Holland
I'm sorry but my German isn't that good so I'll write in english if you don't mind.
I'm compleet restoring a LAF 9121 B.
I'm looking for some technical data about how to connect the box, on the back of the truck, on the chassis.
Does somebody have any picktures or technical data for me?
I like to hear from you.
greetings Tim
Connecting the box to the chassis
Zuletzt geändert von Tim911 am 2008-06-10 8:07:29, insgesamt 1-mal geändert.
If you are able to read in german, you will find a lot of informations using the "Suchen"-function with "Dreipunktlagerung", "Federlagerung" or "Dreipunktlagerung light".
Gruß Ulf
Gruß Ulf
Hi Tim,
a good base for your own ideas is, to read the Mercedes-Benz Body-Building-Directives (in german: Aufbaurichtlinien). These are available in the internet, unfortunately not for the 911B truck, but anyway, the principles are the same.
You can find it here, but it is available in german or turkish only:
ARL_1996_deutsch
P.S.: I am not sure, if the link will work for you. If not, try https://abh-infoportal.mercedes-benz.com to get to the archive of the directives.
ARL_1996_deutsch
Zuletzt geändert von Pirx am 2008-06-10 12:52:56, insgesamt 1-mal geändert.
