Suddenly my truck has started to make a noise in 2. gear. It is a "rrrrrrrrrrrr" metallic. If I hold the gearstick the noise disappears. It is only in 2. gear. Seems to be a vibration that comes up through the gearstick.
Any experiences? Should I not use the gearbox at all, or can I just avoid 2. gear? Or is it "normal"?
Thank you
Magirus 170d11 Noise in 2. Gear. Should I worry?
Peterdenmark
- LKW-Fotografierer
- Uwe
Re: Magirus 170d11 Noise in 2. Gear. Should I worry?
Hi Peter,
did you check the gear linkage if no parts are loose and if guidance is ok? I don't think the noise is coming out of the gearbox...
Cheers
Cheers
saharastar
Hello Peter,
I am 170 D driver as well and encountered similar behave with noise.
However I realized meanwhile that it doesn't come from the gearbox itself. I found out that it is the stick itself because the handheld- bowle at the upper end (what you hold in hand) contain a little screw-nut inside wich was wobbeling (loose hold) and cause the metalic noise.
Hope this is of help/assistance
Best Regards Sascha
Best Regards Sascha
Der Weg ist das Ziel (Laotse)
Peterdenmark
- LKW-Fotografierer
Thank you very much! It is probably something simple like that, I will check the linkage soon
