New member, Iveco Magirus 90-16 AW
SpeedAddict502
#1 Beitrag von SpeedAddict502 » 2016-08-01 16:04:30
Hey guys, hope you are well. I am not sure how many people on here speak English and I didnt know what forum to post this in but this is the only one I saw some other trucks that I know.
I just imported an Iveco Magirus 90-16 AW from Germany. Ive had a Unimog SBU before this, but wanted something with a big cab this time.
I am having trouble finding much information on them beyond the basics, and also want a place to be able to buy parts.
Hopefully some people here can help!
Thanks,
Tyler from Texas
#2 Beitrag von Wilmaaa » 2016-08-01 18:15:20
Hi Tyler!
Welcome to the forum :)
We have a few members who speak English, so feel free to ask questions.
Regarding parts, depending what you need, there are different places to go to.
Which parts do you need right now?
SpeedAddict502
Re: New member, Iveco Magirus 90-16 AW
#3 Beitrag von SpeedAddict502 » 2016-08-01 18:26:09
Awesome! Thank you for the reply!
One of my first questions was about tires. I am definitely switching to super singles and was curious how big you can go on these without rubbing? Several of the pictures of these with big singles I see are linked to this forum, so I was curious how big everyone recommends to go.
As far as parts, it is mainly chassis parts I am looking for. I can actually get Deutz engine parts pretty easy here already, but chassis parts I dont know where to look. The only problem I am having right now is a very bad steering wheel shake at certain speeds. In the US we call this death wobble. It could just be tires, but I think I am hearing a clunk in the front end as well. I am wondering if a tie rod or leaf spring shackle bushing is bad. Is this a common problem, has anyone else had this? I also think I will need a brake fluid reservoir seal as the rear one is leaking brake fluid out of the reservoir.
As far as upgrades, have any of yall added AC? This is something I am looking at doing. What about an intercooler upgrade on the Deutz engine? Is anyone turning up the pumps? What about a PTO winch instead of the front water pump unit? Any other good upgrades?
Look forward to hearing some of your comments!
Tyler
meggmann
#4 Beitrag von meggmann » 2016-08-03 11:00:48
Hy Tyler,
usual tyre upgrades are 12.5/14.5 inch multi purpose tyres (335/80R20 MPT or 365/80R20 MPT on a 11-20 SDC rim).
To upgrade an AC is not very common in Germany and of course some of use try to get the status of an "historical" car/truck (less fees) and so you aren't allowed to upgrade....
Greetz, Marcel
ud68
#5 Beitrag von ud68 » 2016-08-03 12:57:46
Hallo Tyler,
you put a lot of questions into one text. Please let me allow to sort them to get them easier to read. This will hopefully increase the amount of answers.
(recommendation: don't mix tires and motor upgrade and brake questions into one writing. This creates the risk that nothing get answered well)
Q1.) The only problem I am having right now is a very bad steering wheel shake at certain speeds. In the US we call this death wobble. It could just be tires, but I think I am hearing a clunk in the front end as well. I am wondering if a tie rod or leaf spring shackle bushing is bad. Is this a common problem, has anyone else had this?
Q2.) I also think I will need a brake fluid reservoir seal as the rear one is leaking brake fluid out of the reservoir.
Q3.) As far as upgrades, have any of yall added AC (air condition)? This is something I am looking at doing.
Q4.) What about an intercooler (Ladeluftkühler) upgrade on the Deutz engine?
Q5.) Is anyone turning up the pumps? (ESP hochdrehen)
Q6.) What about a PTO winch (Winde am Nebenabtrieb) instead of the front water pump unit?
Q7.) Any other good upgrades?
Tyler
tires 385/65R22,5 upon rim 11,75-22,5 ET110.
If your axles have 8 bolts you need to find suitable rims first. Pls check
* rim widht and diameter
* quantity of bolts and their position and type of the holes
* rim offset (ET)
* speed index
* load index
best regards
SpeedAddict502
#6 Beitrag von SpeedAddict502 » 2016-08-07 3:24:20
Has anyone gotten the 395/85r20 tires to fit?
SpeedAddict502
#7 Beitrag von SpeedAddict502 » 2016-08-10 16:28:46
What is the lug torque for these as well?
SpeedAddict502
#8 Beitrag von SpeedAddict502 » 2016-11-15 23:45:51
Hey guys hows it going. Well I have finally completed a few things I have been wanting to do on the truck. Thought I would post a picture for you to see.
I fit some 12.00R20 tires on it on some 20x10 wheels I had refinished and powdercoated. Also removed the huge side steps for much more ground clearance. I also took the tall ladder racks off the top and just left a few inches for storing items up there. Looks much more tough!
I am thinking about painting the fenders and front bumper black instead of white, but I havent decided on that yet. I am also going to remove the water pump up front but so far have only pulled the driveshaft.
For the guys that have these, are there any common failure points on these I should be looking out for?
I am planning on some long trips coming up but dont to oversee something that can leave me stranded.
This one has only 30k kilometers on it, I am hoping there is nothing too wrong, but I wanted to ask some forum members what to watch out for.
I changed the oil and checked all fluids, however I also want to bleed the brakes, how is that done on these with the air over hydraulic setup?
Thanks!
Tyler
Bdelaporte
#9 Beitrag von Bdelaporte » 2017-08-04 4:25:15
I also have a 90-16 in the US. I am located in WY and have had the truck for only a short time. I had wheels custom made for it and am currently running Michelin XZL military tires as a super single setup. I am hoping to get a copy of repair/service manuals in hard copy or electronic. Does anyone know where I can source a set?
#10 Beitrag von Wilmaaa » 2017-08-04 9:28:46
Welcome :)
I'm not too sure whether the service manuals are available, but you could search the forum for "Bedienungsanleitung" or "Werkstatthandbuch" or "Handbuch" and combine these words with "90 16".
Feel free to ask questions in English, we have a few members here who will answer in English, or we can translate back and forth ;)
rotertrecker
#11 Beitrag von rotertrecker » 2017-08-04 9:40:25
Hi Bdelaporte,
send me your E-Mail, and i will try to send something to you.
Greets Sven
Iveco-Magirus 90-16
MB 515 Minisattel
fennets
#12 Beitrag von fennets » 2017-08-04 9:44:56
Oh an american 90-16, fine
Now im sure " AW" stands for " Arround (the) World" :joke:
Das Herz schlägt Deutz
Was'n ALG?
-Is mein Facebook!
Bdelaporte
#13 Beitrag von Bdelaporte » 2017-08-04 16:43:20
Thank you for the response. The truck is a lot of fun and we have used to to travel around the American West. I look forward to being a member on the forum. Danke
Wilmaaa hat geschrieben:Welcome :)
Bdelaporte
#14 Beitrag von Bdelaporte » 2017-08-04 16:52:46
rotertrecker hat geschrieben:Hi Bdelaporte,
Greets Sven
Sven,
Thank you for the response. My email is bdelaporte@yahoo.com
I would greatly appreciate anything that you may have.
Regards,
Bruce
magictom69
#15 Beitrag von magictom69 » 2017-08-05 11:36:22
SpeedAddict502 hat geschrieben:Awesome! Thank you for the reply!
Tyler
Hi Tyler,
well one of the must good upgrades is to replace transfer gearbox!
Check your "pad" on yours.
Attached one with the best ratio!
Allowed around 13% more topspeed and less speed range...
PN me for more details!
Best regards
80-130AW Norwegen
#16 Beitrag von 80-130AW Norwegen » 2018-06-14 20:04:38
Hi did you solve the problem With the Death Wobble?
I got a 80-130AW w/short Wheelbase.
In Winter time when roads over her are bumpy due to road base freezing I sometimes experience severe Death Wobble.
Truck hits bump in speeds of 60-80 km/t and front wheels start shaking so it is difficult to keep the truck on the road.
I can't fint any wear or slack in the suspension. Truck is only 42000km. Toe in is checked OK. Shock absorbers OK.
I Wonder if the absence of a front track-bar is the reason for the wobble?
SpeedAddict502
#17 Beitrag von SpeedAddict502 » 2018-06-14 21:34:57
Hey thanks for the reply. Mine did end up going away. Mine ended up being the tires. Not sure why as they had great tread and they were the tires that came with the truck, but they were the issue. Toe was good on mine as well, shocks, etc. all good. Put new tires on it with balancing beads, never had the problem again.
Hope this helps!
