Movable cabin walls
Movable cabin walls
Has someone on the forum made a modern insulated cabin with movable side walls? I know the old Robur trucks had a cabin which had (wooden?) side walls which folded out and then three times the space inside. Are these still available and a good idea?
Re: Movable cabin walls
The butterfly-box is quite rare. It could be a good idea if you like tetris...WOODSMAN hat geschrieben:Has someone on the forum made a modern insulated cabin with movable side walls? I know the old Robur trucks had a cabin which had (wooden?) side walls which folded out and then three times the space inside. Are these still available and a good idea?
You have to place everything inside to the middle before you fold the box...
IIRC one Ural fron the Forum has such a "Schmetterlingsbox" and enjoy the translation..
Kind regards
Haerry
P.S. If you go for fixed walls, you`ll never get the corners dust tight.
(Tom Zupancic)
(Tom Zupancic)
Thanks for that. I was thinking extra rooms for sleeping and in bad weather. Second idea was sliding sides of 80CM with all the cupboards sink cooker attached so more space to relax inside the middle. I think Zeppelin made a 10' with extra section on the back in line with vehicle?
Common on expensive motorhomes in the UK/USA.
