170d11 Windows are not waterproof.!
Peterdenmark
#1 Beitrag von Peterdenmark » 2015-06-12 19:19:49
Hi!
The side windows (the ones that roll DOWN) are taking water in along the bottom seal.
Where can I get a seal that will fit? Lkw-restauration say that they do not have that item.
Best regards Peter
cutcorne3
#2 Beitrag von cutcorne3 » 2015-06-12 22:01:43
not sure if I understood your question, but with my MB LA911 my front door roll-down windows regularely take water. It usually runs through the door and out at the bottom. There are holes in the bottom - you just need to ensure that these are open and not covered with dirt. I seem to recall a discussion here where this was the topic and Pirx stated that doors with with crank-operated windows are to be seen as wetzone areas http://www.allrad-lkw-gemeinschaft.de/p ... 33&t=58474
Do an anti-corrosion job of the inner door, ensure that the water can flow out at the bottom so to avoid any fish & frog habitat and you should be good....thats how I do it.
Of course new seals seal better, but you will never get it "waterproof"
Regards,
Peterdenmark
Re: 170d11 Windows are not waterproof.!
#3 Beitrag von Peterdenmark » 2015-06-14 17:54:19
Hi Jochen
You are probably right. But the two rear windows are actually so "loose" that they make alot of noise a s well. So yes, a rustproofing is a good idea but i still need some replacement seals.
Thank you for your reply!
Best regards Peter
cutcorne3
#4 Beitrag von cutcorne3 » 2015-06-14 21:42:54
perhaps try Doepper-profile
http://www.doepper-profile.de/artikelau ... terschacht
if you cannot find anything, make a sectional print of yours and mal them. they are usually quite knowledgable.
Regards,
jochen
