I am trying to figure out how to set the valve clerance on my 170d11 413V
I have the handbook and I have searced the forum intensively for tips and tricks. The problem is that I am not very good at german and google translate makes everything very hard to understand. But I have tried for several days!
So the question is:
In the handbook I read it as if there are 2 ways to set the valves:
1. way is to use the scematics and first find TDC for cyl. 5 (on the kurbelwell there is a small "tip" that marks this right?) With this you can set one or two valves on all cylinders except 5. Then you find TDC for cyl. 1 and you can do the rest of the valves according to the scematics? But where is TDC for cyl 1.? This does not seem to be marked.
2. way (as I read it) is to find TDC for cyl. 5 (both valves are loose) and then set both cylinder 1. valves. Then find TDC for cyl. 2 and set valves on cyl. 6.
Problem is that this does not work. When I have cyl. 5 on TDC (marking on kurbelwelle and both valves loose) then only one of the valves on cyl. 1 is loose.
I am at a loss. Can anyone explain what the best procedure is?
BTW I used the "jacking the wheel up" method and it works perfectly.
