Tuning OM501LA Actros MP1
Hello,
Does anyone know the best way to tune a 1998 Actros MP1 313hp engine for more power and fuel economy.
The truck will be exported and not subject to EU regulations. I have found a few "tuning companies" online offering products, but i'm looking for correct solution. Truck is in Sottrum Germany for a few months.
Cheers.
Cheers.
Re: Tuning OM501LA Actros MP1
I don't think you will get both at the same time.
Maybe not, but the 400 was rated as the most fuel efficient power level. I think the 313 works harder and needs to be run higher in RPM.
I know the company primarily for ECU repairs. The ECUs have been working for years.
I don't know anything more.
I think they know what they're doing.
Regards Uwe
Regards Uwe
Gruss Uwe
ok thank you both.
Edgar
Edgar
Thanks you for help.
Does anyone have recommendation of Mercedes diagnostics and calibration tool. I see various laptops on ebay and have used Icarsoft in the past, but maybe need to more to self service truck correctly.
Also, need to remove speed limit coded into truck somehow. It's governed to around 90km. How can i do this?
Google translate:
Vielen Dank für die Hilfe.
Kann jemand ein Diagnose- und Kalibrierungstool für Mercedes empfehlen? Ich habe mir verschiedene Laptops auf eBay angesehen und früher Icarsoft verwendet, brauche aber vielleicht noch mehr, um den Lkw richtig selbst zu warten.
Außerdem muss ich die im Lkw einprogrammierte Geschwindigkeitsbegrenzung irgendwie entfernen. Sie ist auf ca. 90 km/h begrenzt. Wie kann ich das machen?
Google translate:
