start mit aufbau
Rimburacer
start mit aufbau
#1 Beitrag von Rimburacer » 2007-08-10 20:58:19
last wensday I started building my "Rautenlagerung"
The idea stolen by ENFATEC :angel: bud changed the construction "my way"
The steel has been plasmacut confirm the Autocad drawing i made
That's for now on...., the sandwich panels have been ordered, they will arrive in week 38 :D
Koos
SCANIA P93M 4X4; KING OF(F) THE ROAD!!
Mathias
#2 Beitrag von Mathias » 2007-08-10 21:35:43
hallo!
this looks very good...maybe a littel bit havy...but very good....
i also build a new schelter in the next months....
you can see it in the trade "das perfekte wohnmobiel"
good luck with jour havy-metal.... :rock:
mathias :rock:
Nicht mehr im Forum aktiv!
Joe
#3 Beitrag von Joe » 2007-08-10 22:36:20
Hi Koos,
wow!! Heavy Metal!! :eek: Looks perfect! I hope your construction will have an integrated support frame in the cabin´s ground construction!?!? Otherwise for my feeling a little bit too much additional height which will effect / reduce the cabin's dimensions.
Joe
Rimburacer
#4 Beitrag von Rimburacer » 2007-08-10 22:59:32
Joe hat geschrieben: wow!! Heavy Metal!! :eek: Looks perfect! I hope your construction will have an integrated support frame in the cabin´s ground construction!?!? Otherwise for my feeling a little bit too much additional height which will effect / reduce the cabin's dimensions.
Thanks Joe!! I'll do my best.... :angel:
The cabin will have an integrated support frame ( inside)! don't worry :cool:
The total hight of this construction is 22cm...., not that much I thought?! ( looks may be higher??)Mercedes gives the advice to have a minimum hight of 20cm above the wheels...... so 22cm isn't much more...!
Rimburacer
#5 Beitrag von Rimburacer » 2007-09-20 21:09:05
Next step in building process...
My Panels have been arrived!!! :D
felix
#6 Beitrag von felix » 2007-09-20 22:44:57
Hello,
sexy! Like the other writers: A little bit heavy, but it looks very professional. Perfect placement on the vehicle-frame. It will work in every situation. 22cm is the idle high, otherwise the space to the vehicle-frame and the wheels would be to small for serios off-road use.
A litte Note: When you build the support-frame for the cabin notice, that you use rubber for the fixed, middle bearing. The outer bearings are made of steel. So vibrations would onely be supportet by the steel-bearings, in case of vibrations the rubber would conduct as if it is not there. Pay attention to this, when you make the plannins for the support-frame.
On the other hand, a cabin is onely strong in its corners, so it would bring a lot stability itself near by the steel-bearings. And this would be the next Note: The rubber-bearing is the onely bearing that supports "right/left" forces. But the cabin does not bring a lot of stability in its middele. So enshure that the support-frame would avoid torsion to the cabin-structure.
I hope my english is good enaugh to explain what i wanted to say...
MlG,
Rimburacer
#7 Beitrag von Rimburacer » 2007-10-09 19:14:29
Well, started with the next step....
rocknroll
#8 Beitrag von rocknroll » 2007-10-09 22:16:18
Sorry i can't c the last two Pics,
meaby its possibile that you put it aggain int the Forum?
Thanks a lot
greez
Rock
Zuletzt geändert von rocknroll am 2007-10-09 22:16:41, insgesamt 1-mal geändert.
Kami
#9 Beitrag von Kami » 2007-10-10 2:59:11
@rock: i can see them, maybe your pc has a problem with you? :lol: :lol: :lol:
bye
Kami
rocknroll
#10 Beitrag von rocknroll » 2007-10-10 12:54:57
Kami hat geschrieben:@rock: i can see them, maybe your pc has a problem with you? :lol: :lol: :lol:
bye
Kami
Ich glaub eher der hat das sogar mit der Rest der Welt.
ich kann die ersten bilder halt sehen , nur die letzten 2 nich.
und dekompre programme hab ich auch die neusten drauf
:huh:
also was tun? :(
hano-mac
#11 Beitrag von hano-mac » 2007-10-10 16:17:21
schonmal versucht, die fehlenden bilder im eigenen fenster zu öffnen? schonmal den brwoser-cache geleert?
http://img119.imageshack.us/img119/2360/dscn2077kb2.jpg
http://img119.imageshack.us/img119/7718/dscn2076fg2.jpg
viel erfolg
sven
...öttel...öttel...öttel...
Monny
#12 Beitrag von Monny » 2007-10-10 21:30:56
no problem with the pix here...
Gruss,
Monny
Deutschland 1968:
"Mama, fahren wir mal die Oma besuchen?"
"Das geht leider nicht, mein Kind, die Oma wohnt in der Zone"
Deutschland 2008:
sugar
#13 Beitrag von sugar » 2007-10-11 10:32:08
@Rock,
vielleicht ist der Weg von GB nach Konstanz auch zu weit...
Also in Dortmund klappt et noch!
:D
sugar
Rimburacer
#14 Beitrag von Rimburacer » 2007-10-11 21:40:36
and the story goes on....
rocknroll
#15 Beitrag von rocknroll » 2007-10-11 23:04:34
it a good work, you mußt be a good craftsman.
How did you fill the bottem from the Shelter?
Rock
PS: now the pics all work
Rimburacer
#16 Beitrag von Rimburacer » 2007-10-12 19:25:05
Thanks Rocknroll, you can answer in the German language! that's no problem for me, reading and speaking isn't the problem.... the writing is....... :blush:
And the story goes on and on....... :angel:
That's it for today, tomorrow the roof and the corner covers! :cool:
Lassie
#17 Beitrag von Lassie » 2007-10-13 2:14:05
I have also built my box alone. I am wondering a bit - your side panels are made with a wooden frame?!
How to connect them to each other? Did you just use glue and L-shaped aluminium profiles?
Just curious, Juergen
Pictures of my box: http://www.jlaske.com/unimog3.html
Rimburacer
#18 Beitrag von Rimburacer » 2007-10-13 21:52:01
Hello Lassie
Here you can see how my floor/ box is build up
and well..... The box is closed!!!!!
rocknroll
#19 Beitrag von rocknroll » 2007-10-14 12:42:29
na dann schreiben wir doch in deutsch.
Serh schön gemacht!
Fragen: Die Bodenpaltte, sind das 2 Platten und dann darauf der Bodenrahmen?
Ist eine der Platte aus Holz, oder sind beide Platten so aufgebaut das nur am Rand Holz ist?
Wie ich sehe hast du die Platten geschraubt. Oder täuscht das?
Hast du die Platten noch verklebt an den Holzverbindungen?
@ Joe , du bekommst konkurenz :D :D
Rimburacer
#20 Beitrag von Rimburacer » 2007-10-14 21:01:06
rocknroll hat geschrieben:na dann schreiben wir doch in deutsch.
Serh schön gemacht!
As you can see, the floorpanel has a wooden frame inside with about the same sizes as the aluminium frame....
The alu frame will be filled up with pur and glue after the gas/water/electra-lines have been mounted. The wooden floor will be glued too!
The screws were just to keep the panel in place during the drying proces of the glue ( 2-k glue)..., they could be removed now ( but i won't do that.... :D )
This construction is calculated and verry strong!!!
THE HELL HE DOES!!!!!! :D :D :D
Zuletzt geändert von Rimburacer am 2007-10-14 21:05:23, insgesamt 2-mal geändert.
gunther
#21 Beitrag von gunther » 2007-10-14 22:01:16
das sieht doch schon super aus und man kann sich den Aufbau der Platten doch vorstellen. Ich dachte schon das sind Vollholzplatten
Wie lang ist denn dein Koffer Koos?
Kommt da noch Fussbodenheiung rein / obendrauf?
Hast du einmal dein Fahrzeug leer (ohne Rautenlagerung und Koffer gewogen?
Ich bin mal gespannt wie schwer der Wagen mit dem Koffer ist.
es wäre schön wenn du uns die Daten mal geben könntest.
Koss, hast du keine Bedenken, dass bei einem Temperaturunterschied von bis zu 60° Sommer / Winter , der Kofferboden GFK gegenüber dem Aluminiumrahmen sich nicht unterschiedlich ausdehnt? oder bewohnt Ihr das Fahrzeug das ganze Jahr, so dass hier innerhalb des Fahrzeuges keine so grossen Temperaturunterschiede auftreten werden?
Alpha bei Holz ist 8 gegenüber bei Aluminium von 23.
Ansonsten würde ich wahrscheinlich statt dem seitlichen Kleber an dem Profilrahmen lieber ein wenig Abstand zur Kofferwand zur Ausdehnung lassen
Gruss Gunther
Zuletzt geändert von gunther am 2007-10-15 14:42:51, insgesamt 2-mal geändert.
Rimburacer
#22 Beitrag von Rimburacer » 2007-10-16 23:30:02
gunther hat geschrieben:das sieht doch schon super aus und man kann sich den Aufbau der Platten doch vorstellen. Ich dachte schon das sind Vollholzplatten
Danke!
gunther hat geschrieben:Wie lang ist denn dein Koffer Koos?
502 cm
gunther hat geschrieben:Kommt da noch Fussbodenheiung rein / obendrauf?
Obendrauf...., I'm planning to go to the sunny ( :cool: ) side of the world... :D and would only need it during cold nights with a lot of stars.....
gunther hat geschrieben:Hast du einmal dein Fahrzeug leer (ohne Rautenlagerung und Koffer gewogen?
Forgot it now :wack: but i'm gona lift the cabin once (for painting the chassis) and will weight the chassis then.....
gunther hat geschrieben:Ich bin mal gespannt wie schwer der Wagen mit dem Koffer ist.
Me too!!
gunther hat geschrieben:es wäre schön wenn du uns die Daten mal geben könntest.
See PM
gunther hat geschrieben:Koos, hast du keine Bedenken, dass bei einem Temperaturunterschied von bis zu 60° Sommer / Winter , der Kofferboden GFK gegenüber dem Aluminiumrahmen sich nicht unterschiedlich ausdehnt? oder bewohnt Ihr das Fahrzeug das ganze Jahr, so dass hier innerhalb des Fahrzeuges keine so grossen Temperaturunterschiede auftreten werden?
The glue between the aluminium and the panels ( floor and walls is specialy for glueing different materials ( quite flexible)
Gruss Koos
karakum
#23 Beitrag von karakum » 2007-10-17 17:08:38
Hi Koos,
impressive solution!
One of my (probably stupid) questions:
You fix your cab at the backside, at the center and at the front, right?
Is somebody here to explain me in German or English the reason for the center axle?
sugar
#24 Beitrag von sugar » 2007-10-18 20:28:58
@karakum
das ist eine Rautenlagerung, das vordere und das hintere Lager sollen die flexibilität in Querrichtung gewährleisten, das mittleres Lager dient der flexibilität in Längsrichtung. Deshalb drei bzw. eigentlich vier Lagerstellen da die mittlere an beiden Aussenseiten aufgelegt ist.
sugar
karakum
#25 Beitrag von karakum » 2007-10-19 9:06:58
Danke, verstanden. Vom Bewegungsablauf leuchtete mir eine §- Pkt- Lagerung leichter ein.
Angesichts der Diskussion um die gezeigte sehr stabile Ausführung stellt sich mir die Frage, welche Dimensionierung für einen 7,49t LKW angebracht ist. Hat wer schon mal Materialberechnungen angestellt?
Rimburacer
#26 Beitrag von Rimburacer » 2007-10-27 18:04:24
AND FINISHED!!!( for so far........)
Zuletzt geändert von Rimburacer am 2007-10-27 18:04:51, insgesamt 1-mal geändert.
