Tools for spring suspension removal on ex-THW Magirus 170D11
Nomadis
#1 Beitrag von Nomadis » 2008-03-10 15:05:11
Hello
On my ex-THW Magirus 170D11 I need to remove the front spring suspension for repair.
I see two adjusting screws with 4 holes (Einstellschrauben) which logically require special tools for removal such as Magirus pin spanner WU 135 (Zapfenschlussel) and srew clamp WU 136 (Zwinge); so two questions :
- Do I really need those Magirus tools, or can I use some universal adjustable pin spanner (often only 2 pins)?
- Where to find/purchase those Magirus tools for cheap?
Thanks
Mathieu (France)
(Sprechen Englisch o Französisch)
#2 Beitrag von Uwe » 2008-03-10 21:03:47
Hello,
I think a universal pin spanner will do.
Do you have to fix the spring pin or just the spring leaves? Maybe it woud be easier to disassemble the spring pack...
#3 Beitrag von felix » 2008-03-10 21:32:35
Hello,
i dont't think thre is any sullyer for this tool. You can build this tool yourself or remove the screw without it.
