iveco 110-16 camper refurb
Verfasst: 2012-01-21 20:58:52
von allan
Re: iveco 110-16 camper refurb
Verfasst: 2012-01-21 22:46:12
von Deutzinside
Nice Color....................
Verfasst: 2012-01-21 22:54:19
von pvirkus
Nice Car - Good work
Verfasst: 2012-01-21 23:49:30
von Alter Schwede
Well done, sophisticated work! Thumbs!
Grettings
Verfasst: 2012-01-22 2:45:54
von WOODSMAN
Good sized workshop to use.
Verfasst: 2012-01-22 8:47:39
von rallytruckschrauber
Hey Allan,
nice work,nice car...and welcome here:-)
I hope I see you been to a truck meeting.
Best regards Stefan
Verfasst: 2012-01-22 20:16:27
von Veit M
Looks nice.
The light color on frame and axles will help to see something. With black color this is always like a black hole.
Good luck with the shelter. With 6m you will have plenty of space.
Have a nice day.
Veit
Verfasst: 2012-01-22 23:31:05
von MarkusG
The Truck is OK
Verfasst: 2012-01-23 15:59:02
von pairospam
Hi, Allan:
Nice truck and pretty nice job for sure.
How did you manage to clean the frame and components before painting? Did you dissasemble them?
I am having a hell of work taking off the cables, piping, tecalans and some supports to clean every corner before even thinking of painting my own truck.
Cheers.
Pairoa
Verfasst: 2012-01-23 16:40:27
von Uwe
MarkusG hat geschrieben:The Truck is OK
Für einen Oberfranken die höchste Form des Lobs
*duckundweg*
Verfasst: 2012-01-28 18:29:38
von allan
Hi Pairospam,
For the preparations, i think you are overdoing it by removing all the cables etc. I also have to restrain myself from not going overboard and take all appart to make it perfect. I dont know the condition of your truck but mine was with only minimal rust in a few places. Taking everything appart will only risk that it will start leaking etc when assembled again. Especially the air system i dont want to mess with.
I used a HP steam cleaner for everything and with the 125 degree celcius steam, it removes all grease, tar and even rust scale and loose paint. I used a cup steel brush on an angle grinder to remove any remaining rust and that was it. For very tricky spots on the transmission etc i used a hobby sand blasting gun.
For the painting, i used marine paint from Hempel as it is far better than what you get from a normal paint shop and buying for a complete truck in a local car paint shop will cost a fortune. Use to different colors for the primer though, it makes the job so much better if you can see any corners etc not covered by the second layer. A spray gun will make the job almost fun and so much better than a brush. It also allows you to apply a thicker layer of paint. The marine paint also helps here as it does not have the tendency to run as easy as other paints.
rgds Allan
Verfasst: 2012-01-30 17:08:55
von pairospam
Hi Allan:
Thanks for your reply.
Unfortunately it seems that my truck had worked for the last thirty years without too much care from his owners and even if the rust is quiet important the dirt and the oil/grease/dirt issue is very important as well. As I quoted, for a good job I can do do no less than take everything off, no matter if I am happy or not doing it. I have to make order and to clean all the components of the brake system so I have to disassemble everything too, so I will have to deal with leaks if I have to. Life is hard.
But you gave me a good idea for I had not thought about using a steam power washer before and that could be a nice thing to do to clean some pretty nasty difficult-to-reach corners.
It can be seen that you have worked a lot on your truck and the result is quiet excellent.
Enjoy the rest of the building and let us know.
Cheers.
Pairoa
Verfasst: 2012-05-19 12:14:07
von allan
Set back by work quite a bit (what a waste of time.....
but finally got a long weekend to get the cabin started. Went quite well and im happy with the proportions and progress. The plating solution will give me no visible rivets and it will end up looking quite "clean" with only an angle on the top and bottom. Need to find a nice one like the trucks have on the reefer boxes though.
A few pictures of the progress so far:
