maximum drehzahl F6L413V
Erwin
#1 Beitrag von Erwin » 2007-09-05 15:58:49
Hello,
Because I don't have a "drehzahlmesser" in the truck, I would like to install one, but I would like to know what the maximum "drehzahl" is of an F6L413V engine. Does anyone know?
I also need it to calculate which "Zyklonfilters" I have to install.
I have found the formula in the old forum, but I need to know what the maximum air intake is and therefor I need the maximum "drehzahl". The truck is an 170D11.
Thanks already!
felix
#2 Beitrag von felix » 2007-09-05 16:07:30
max RPM: 2650.
(Do not forget, that you have a 4-stroke engine, when you calculate the "Zyklon": Max 11m³ per minute)
MlG,
HANOMADEU
#3 Beitrag von HANOMADEU » 2007-09-10 17:15:19
Hello Erwin,
Engine speed max. amounts to 2650 rpm.
Combustion air quantity amounts to 605 m ³ /h
The F 6 L 413 V has only one inlet and an exhaust valve!
