Help Needed - Broken Down at Side of Road -Argentin - MAN L2000 D0836LFL 03a
DavidQ
#1 Beitrag von DavidQ » 2024-04-22 18:19:38
Hi, we found some German overlanders broken down beside road. L2000 EDC red light on. Grey smoke from exhaust. Suspect fuel pump. Does anyone have MAN information/manual for D0836LFL03 engine so that we may try to help them?
Thank you
David
Re: Help Needed - Broken Down at Side of Road -Argentin - MAN L2000 D0836LFL 03a
#2 Beitrag von Wilmaaa » 2024-04-22 18:30:03
You could try contacting Wombi. He's travelling in south America and also an MAN expert.
Maybe he'll write something in this thread, too.
Strom
#3 Beitrag von Strom » 2024-04-22 19:03:42
Moin.
Gut möglich, das es der gleiche Fehler wie hier ist: viewtopic.php?f=31&t=107205
Fehlerbild passt ...
Ich antworte bewusst nicht auf englisch, möchte nicht für körperliche Schäden eines Lachanfalls verantwortlich sein :joke:
Nelson
#4 Beitrag von Nelson » 2024-04-22 20:27:32
Do you have engine number (14 digits) and chassis number (17 digits)? For my truck I there are several information provided online (with registration). For example there was an EDC manual with troubleshooting. Just I never had a look on these manuals before and I have no experinece how far they are helpful for screw driving on the road.
The enginge you mentioned should have EDC MS6.4 acoording to the general manuals. For EDC MS5.3 from my engine I had a look on the troubleshooting. In case of white or blue smoke:
-Air in the fuel system (ignition has to be on when fixing it)
-cable problem with connector between ECU and injection pump (connectors at injection pump, ECU, front of cabin)
-injection pump; several parts can get stuck mechanicly or have an electric short circuit
Sounds like there are some easy possibilities to check
Nils
Wombi
#5 Beitrag von Wombi » 2024-04-22 22:00:31
Wo stehen die denn ???
Wher are they right now in Argentina ???
Wombi
DavidQ
#6 Beitrag von DavidQ » 2024-04-23 1:51:04
I PM'd you Wombi
negele
#7 Beitrag von negele » 2024-04-23 14:02:36
Wombi hat geschrieben:
2024-04-22 22:00:31
Wombi
Hallo Wombi,
die gestrandeten sind Christine und ich, Rolf. Wir stehen hier: https://maps.app.goo.gl/39ixFbEVCT8ujRwNA?g_st=ic
Gestern hat uns ein argentinischer Mechaniker geholfen. Die Kraftstoffanlage geprüft und entlüftet. Der MAN ist angesprungen und hat nicht mehr geraucht (Luftfilter gereinigt). Nach 15 Min. Lauf im Stand ist er abgestorben und startet nicht mehr. Ratlos 🤨
Zur Info, wir sind L2000 Fahrer und leider keine Mechaniker. Hilfestellung muss bitte für „Dummys“ sein 🙈
ingolf
#8 Beitrag von ingolf » 2024-04-23 15:37:04
Hallo ihr 2,
habt ihr denn dem Mechaniker zugesehen und wisst, wie ihr Diesel pumpt und entlüftet? Kraftstofffilter wechseln vorher und dann noch einmal versuchen?
Grüße, Ingolf
Flocken statt Feinstaub !
Thognes
#9 Beitrag von Thognes » 2024-04-23 16:19:21
Strom hat geschrieben:
2024-04-22 19:03:42
OT:
Hallo Michael,
nix gegen heftige Lacher, aber guck Dir vielleicht mal deepl (www.deepl.com) als Übersetzer an; ist kostenlos, gut in Mac wie wohl auch PC einzubinden und sehr zuverlässig.
Und wenn Du das bei längeren Texten abschließende "Translated with DeepL.com (free version)" nicht mitkopierst, merkt es auch niemand :angel:
Thorsten
(Überarbeitet und OT hinzugefügt)
„Es gibt Menschen, die reden soviel, daß sie sich auch selbst noch ins Wort fallen." (Georg Christoph Lichtenberg)
„Den größten Fehler, den man im Leben machen kann, ist, immer Angst zu haben, einen Fehler zu machen.“ (Dietrich Bonhoeffer)
