Actros / SK 1990s
Re: Actros / SK 1990s
I think those are the lower (slow axles). I’m not sure though.
- Uwe
We are talking about hub reduction axles, so 5,1 ist rather long. And since all Actros MP1 4x4 will have these axles, there is not much of an alternative - and these are mostly shorter
Ok. I’m looking at an AK this week and trying to figure out if it will cruise at 100kph ok. It seems some of these trucks aren’t register so a test drive is a challenge.
https://youtu.be/KynjT9ZjWJ4?si=acqQFirR40vt4VsY
Are there higher gears than this truck has? Seems to be very Lowe geared.
Do you have any knowledge on changing the planetary gears? Is that something that can be done on these trucks?
I looked at the truck and it's running 2100RPM at 100Kph with the standard tires. I don't think that's good for driving long distances.
It also has the Trilex wheel system, which would need to be exchanged for standard wheels in my opinion.
Thoughts?
Hi sprocket3!
Not 100% sure, but IIRC there are no planetary gears with a different ratio. The usual way to change the axle ratio ist to swap the differentials.
Anyway, in my opinion there ist no need to work on the axles. Just put on bigger tyres (14.00R20 should be great) and you are fine.
The Trilex wheel system could be with special axles designed for it or with standard axles and Trilex-Adapters. With the adapters, a change of the wheels should be no problem.
Otherwise you have only this possibility for change to Single. Trilex-Tublex Single Tire Switch.
This is the only safe way and no rim cut or anything. It's like Pirx writes. If it is a disc wheel rear axle then a Trilex adapter is installed. Otherwise a narrow trilex rear axle. These Parts to convert are not all longer available. Another Rims from US or Australia have not the same Angles and distances like GF from Europe. Looks the same, but it's not.
There are 3 different gear ratios for planetary sets( i have only for the outer Sun Wheel the 19 tooth and 25 tooth on my head), but not for every axle type. This would have been available for my axle, but not every part is available anymore.
Here too, the easier way and certainly available is what Pirx writes and you swap the differentials.
Greetz Uwe
Unfortunately I can no longer find the gear ratios for the 3 Types
Greetz Uwe
I thought of the tires, but I think I can only gain about 10% which still puts truck cruising at nearly 1900. Seems like that’s near max RPM for engine.Pirx hat geschrieben: ↑2024-03-29 14:44:24Hi sprocket3!
I’ve done differential gear changes on light duty trucks and it was a headache. What’s the cost on an SK for a well done diff change? Seems like something that could costs 15,000 euro.Borsty hat geschrieben: ↑2024-03-29 15:33:22Otherwise you have only this possibility for change to Single. Trilex-Tublex Single Tire Switch.
Greetz Uwe
I don't know it. I never asked for the SK.
Ring and Pinion ask by Euroricambi.
Does anyone know the Trilex part number meaning?
The rear trilex center section has a part number on it of # 105496e. I think it's an E last digit. Hard to tell. Is this an adapter ring or it's the full trilex hub that needs to be dealt with.
The front is # 7868 which i think is just an adapter.
Sorry for all the questions. I'm trying to make a decision on this truck.
Sorry for the late answer. Unfortunately the numbers don't mean anything to me
This is a Adapter from rear as example This is the Trilex rear wheel hub You can see that the hub is detached.
And this is the Adapter in Front You see the 10 bolts brake drum with the Adapter.
On page 217 you can see what they look like at Mercedes or MAN or Scania.
Many people don't recognize at first glance whether they are adapters or Trilex axles and some people barely know the system.
Greetz Uwe
Greetz Uwe
Thank you so much for posting those photo. It's definitely got the Trilex Hub on the back. I think it's the adapter on the front though. I didn't take very good photos of the front when i was there.Borsty hat geschrieben: ↑2024-04-03 7:22:27Sorry for the late answer. Unfortunately the numbers don't mean anything to me
Greetz Uwe
Assuming this, what would be the budget to convert rear to standard hubs? I did a lot of reading and it sounds way more complicated that one would expect. Not just changing the hub.
No Problem. So, i think you have a Swiss version with a width of 2.30m. In this case, the handlebar/push rod is also more bent so that the wheels have space at the front. What irritates me about the data card is the code R88 Tublex rims 8.25-22.5, narrow, for 12 R 22.5 sales but not the axle and the adapters.sprocket3 hat geschrieben: ↑2024-04-03 16:06:05
Unfortunately, there is no longer any material available to swap to normal hubs and is very complicated. In addition to the hubs, the brake drums would also have to be replaced, etc. In terms of price, you can almost get a new axle. For single tires the only way is what I had done. Officially with papers and registered to the vehicle. A rim without a tire instead of a twin wheel is rubbish. In a pinch, yes, but not for a longer trip.
Greetz Uwe
Well I don't think i should buy this truck now. I really need to be have Single rear tires and have a standard wheel system. Thank you very much for the help sorting this out. I had hopes that it was something that could be changed easily.Borsty hat geschrieben: ↑2024-04-03 21:31:40No Problem. So, i think you have a Swiss version with a width of 2.30m. In this case, the handlebar/push rod is also more bent so that the wheels have space at the front. What irritates me about the data card is the code R88 Tublex rims 8.25-22.5, narrow, for 12 R 22.5 sales but not the axle and the adapters.sprocket3 hat geschrieben: ↑2024-04-03 16:06:05
Greetz Uwe
I understand. Unfortunately, it's not easy and it's not cheap either. I went this route because I didn't want to get too wide and I liked the Trilex system firstly and secondly because it was easy to mount on wheel bolts without having to center the rim. I just have to turn the driver stop appropriately and this can be done very easily by hand when the wheel is resting on the Trilex adapter. No need to lift a lot of weight, everything is easy with the assembly levers and tubes that are part of the system. My intervertebral discs thank me. I would have been happy with a normal wheel system but with Trilex adapters. But the Trilex system was already anchored in my head.
Good luck with your further search. I would also extend this to Switzerland as good vehicles are always offered here at normal prices. For example
Greetz Uwe
Greetz Uwe
Is there a good site that most of the trucks are listing on there? I have been using mobile.de and autline.com and thought that would pull the Switzerland trucks too.Borsty hat geschrieben: ↑2024-04-04 7:25:59I understand. Unfortunately, it's not easy and it's not cheap either. I went this route because I didn't want to get too wide and I liked the Trilex system firstly and secondly because it was easy to mount on wheel bolts without having to center the rim. I just have to turn the driver stop appropriately and this can be done very easily by hand when the wheel is resting on the Trilex adapter. No need to lift a lot of weight, everything is easy with the assembly levers and tubes that are part of the system. My intervertebral discs thank me. I would have been happy with a normal wheel system but with Trilex adapters. But the Trilex system was already anchored in my head.
Greetz Uwe
- karussellbremser
- LKW-Fotografierer
most notorious:
tutti.ch
ricardo.ch
basisfahrzeuge.ch
most notorious:
tutti.ch
ricardo.ch
basisfahrzeuge.ch
Also in use
anibis.ch
autoscout.ch is the same its give in Germany
armyliqshop.ch It also has trucks from time to time. But here you have to send an offer and it's a risk because you can't look at the vehicles. There is usually a list of what exactly is broken, but this is not exhaustive. A lot of army trucks go to Germany or Holland.
HtH
Greetz Uwe
anibis.ch
HtH
Greetz Uwe
Well i just bought tickets to fly back to Europe for 30 days. Heading your way the 26th. I hope i have better luck this trip.
Let me know if anyone sees anything good.
WDB6523031K227359
Can anyone decode this vin really quick? Trying to look at it today, but don't want to go if it's got really low gear.
C652303(30B)1824 AK/LAK,1827 AK 1831 LAS
Motor:44592510905828 (38V)OM 441 LA
Mechanisches Getriebe:71467410451256 (04D)G 4/110-6/9,0 + NA 4/120-1C
Lenkung:76588316275004 (22W)LS 8
Aufbau:64181515266534 (55P)641
Vorderachse 1:731621F031035 (12J)AL 3/9 D-6,8
Hinterachse 1:748902V370241 (18F)HL 7/26 D-12,3
Verteilergetriebe:75081310011214 (25E)VG 900-3 W/1,691
Code Bezeichnung Codeart
A40 Aktuell keine Code-Benennungen vorhanden sales
A70 Differentialsperre Vorderachse sales
A71 Differentialsperre Hinterachse sales
A75 Achse, Planetengetriebe i = 4,000 sales
A87 Achsteile für ABS sales
B02 Antiblockiersystem (ABS) sales
B08 Geräuschmaßnahmen Bremsanlage sales
B43 Anhängerbremse 2-Leitung sales
B65 Drucklufttrockner, beheizt sales
C37 Hinterfedern stärker, Stufe I sales
C53 Lenksäulenhalter, verstellbar sales
CF1 Fahrgestellumfang Euro II-Motor sales
CL9 Lenkung LS 6/LS 8 sales
D05 Fahrerhausteile, M-Fahrerhaus sales
D75 Einstieg sales
D79 Elektronik-Bausteine, Aufbau sales
D87 Zusatzteile, Differentialsperre sales
DA9 Öleinfüllrohr sales
E18 Befestigung, Elektronik-Bausteine sales
E20 Batterien verstärkt, Stufe II sales
E40 Anhängersteckdose, 7-polig sales
E98 Spannungswandler, 24/12 V sales
EA1 Sicherungsdose zusätzlich, Klemme 30 sales
EA2 Sicherungsdose zusätzlich, Klemme 15 sales
EA3 Sicherungsdose zusätzlich, Klemmen 15R+D+ sales
EE3 Vorrüstung Elektrik, Nebenantrieb bei FMR sales
F05 M-Fahrerhaus sales
F12 FAHRERHAUS-SCHWINGUNGSDAEMPFER VERSTAERKT sales
F35 Fahrerhausrückwand mit Fenster sales
F52 Sonnenblende außen, transparent sales
F60 FAHRERHAUS KOMFORTLAGERUNG VORN sales
FL1 Facelift sales
G19 Getriebe G 4/110-6/9,0 sales
H04 Wärmeisolierung, zusätzlich sales
IL2 Export-Code sales
J53 BREMSBELAGVERSCHLEISSANZEIGE sales
K15 Haupttank rund, 300 l sales
KH1 HAUPTSCHALLD. SEITL.AN RAHMEN LI.(BIERFASSLOESUNG) sales
KH4 Auspuff, seitlich am Rahmen, groß sales
L04 Tagfahrlicht, automatisch sales
L30 Steinschlag-Schutzgitter, Scheinwerfer sales
LB2 Vorrüstung Markierungsleuchten, seitlich sales
M41 Generator 28 V/80 A sales
MB1 Motorbremse, mit Konstantdrossel sales
MC1 Motor, V6, LA, 180 kW (245 PS), 2100/min, Euro II sales
MK0 VORRUEST.F.EXTERNE MOTORREGELUNG M. KOMFORTSCHALT. sales
N53 Motorabtrieb hinten, für Hydraulikpumpe sales
R04 Radmutternabdeckung sales
R37 Steilschulterfelgen 8,25 x 22,5 sales
S68 SICHERHEITSGURT AUTOMATIK FAHRERSITZ sales
S69 SICHERHEITSGURT AUTOMATIK BEIFAHRERSITZ sales
SE1 Fahrer-Komfort-Schwingsitz, Isringhausen sales
X57 Geräuschmaßnahmen, EG 96/20 sales
X94 WEGFALL ZIERSTREIFEN / DEKORSTREIFEN sales
XS3 Hinweisschild "G", lärmarm nach §49 STVZO sales
Y18 FLEXIBLES DIAGNOSE SYSTEM (FDS) sales
Y20 Bordwerkzeug, Export sales
YA9 WEGFALL ZENTRALSCHMIERANLAGE sales
YB9 C5-Elektronik sales
Z91 Export-Lieferumfang sales
255U gelborange sales
904O tiefschwarz sales
